Old 18-09-2018, 09:06 PM   #1
kingswood
kingswood's Avatar
Any sparkys want to try and fix my DA please?!
Got a Argos challenger DA a few years ago and been working well untill today. Had an intermittent fault cutting out but wiggling the wire seemed to make it work.
Finished the car and thought it mite have come loose inside so took the back off. All the wires seemed ok and it still worked giving them a wiggle. Cldnt see no loose connections etc. Then it stopped working full stop :-/ checked fuse in plug and all ok.
Can post out if some one fancies a challenge to fix it please. It doesn’t owe me anything so if it gets lost in the post or can’t be fixed then no prob. Will package and PayPal postage :-) plus a pint - London prices :-)
Many thanks
kingswood is online now   Reply With Quote
Old 18-09-2018, 09:38 PM   #2
A&J
A&J's Avatar
Check the electric brush...maybe it only needs a replacement.
Old 18-09-2018, 09:46 PM   #3
bigalc
bigalc's Avatar
This was exactly the same problem I had with my DAS6, turned out it was a break in tthe cable about 6 inches from the machine , a friend of mine cut the cable and re attached.
The Following User Says Thank You to bigalc For This Useful Post:
Malakkastraat (20-09-2018)
Old 18-09-2018, 09:48 PM   #4
detailR
detailR's Avatar
I'll have a go if you like.
I've fixed a few for people in the past.
www.detailR.com
Milton Keynes - Buckinghamshire
Ceramic Pro - Auto Finesse - ODK Wax - PVD Approved SunTek Paint Protection Film
Instagram @detailr Facebook @detailR
detailR is online now   Reply With Quote
The Following 2 Users Say Thank You to detailR For This Useful Post:
Jamesrt2004 (18-11-2018), Jue (24-09-2018)
Old 18-09-2018, 09:50 PM   #5
kingswood
kingswood's Avatar
thanks for the replies
i thought that so as u can see in the pic i cut the cable but the wigglying wires was above how far i had cut so think it was one of the four pins onto the circuil board :-/
Old 18-09-2018, 10:04 PM   #6
kingswood
kingswood's Avatar
thats great thanks :-) keep the wife off my back as darn't ask for a new one!
i'll pm you
Old 18-09-2018, 10:27 PM   #7
gishy
We have a lot of angle grinders at work and this is a common problem ,usually a break in the cable just below the handle.exact same symptoms intermittent then packs in completely.does give you the chance to put a longer cable though.
gishy is offline   Reply With Quote
The Following User Says Thank You to gishy For This Useful Post:
Old 18-09-2018, 10:32 PM   #8
RedUntilDead
Was going to say the same. Fixed loads of hand held appliances at work due to breaks in the cable. Easy step is to replace cable if nothing else is obvious
Old 20-09-2018, 09:48 AM   #9
detailR
detailR's Avatar
The machine arrived this morning.
As expected, a break in the cable.
It was on the neutral side as it enters the machine.
All up and running again
Have it a little service too - checked brushes, greased the hearing.
www.detailR.com
The Following 5 Users Say Thank You to detailR For This Useful Post:
A&J (20-09-2018), big dave 666 (18-11-2018), gishy (20-09-2018), Jamesrt2004 (18-11-2018), Jue (24-09-2018)
Old 20-09-2018, 10:34 AM   #10
A&J
A&J's Avatar
Great job mister Awesome deed
