Old 23-04-2021, 09:47 PM   #11
Rappy
Thanks for this
Rappy is online now   Reply With Quote
The Following User Says Thank You to Rappy For This Useful Post:
Sheep (24-04-2021)
Old 24-04-2021, 12:26 AM   #12
Sheep
Sheep's Avatar
Originally Posted by JU5T1N View Post
When sanding you could use no pressure, go in 1 direction and count the number of times you go back and forth so you have a method thats easy to repeat and will produce results similar enough for the test. I think polishing just adds more variables that will make it more difficult to get similar results.
That is a good option, but If I put in sanding marks that a light polish can't fully remove, I should have a decent defect level and still have it worked in evenly (not just grinding in 1 direction). I'll play around with it this weekend and see what I end up with.
Old 24-04-2021, 07:38 AM   #13
Sheep
Sheep's Avatar
Picked up a pack of Wet sand paper. All of them are velco backed (7 inch size though...) ranging from 1000 to 3000. What I think I'm going to do is do a section with 2000 and a section with 3000 and polish them both with a couple different light polishes and see how the results look. If 2000 is a bit too much I'll use 3000 and let the black fender be my haze/fill panel going forward.
Panel setup on my winter rims, ready for a wetsand and polish over the weekend.
Untitled by brianjosephson1, on Flickr
It could really use it too.
The Following User Says Thank You to Sheep For This Useful Post:
JU5T1N (24-04-2021)
Old 24-04-2021, 07:26 PM   #14
Sheep
Sheep's Avatar
Ok, did a quick round of wet sanding and polishing today to see how the seconds would take to a couple light polishes, and to see how well I can wetsand without ever having done it before - Spoiler alert, I suck.
In my defense, this panel is extremely non flat so getting into the dips and valleys was hard. It was also hard to keep it still so I had to jump between wetting and holding.
I used Meguiars Ultimate Polish and Optimum Hyper Polish as my tests, and did one section per grit (2000 and 3000 grit). Things looked good after the wipe off but panel wipe showed that a lot of defects were left behind. The results say that 3000 should be a good pairing for Megs UP (easier to restock than Hyper Polish) and once I get better at wet sanding (or use the other fender - its flatter) I should be good to go. Pics below.
2000 grit after drying off.
3000 grit after drying off.
3000 grit UP after panel wiping.
3000 grit HP after panel wiping.
2000 grit HP after panel wiping.
2000 grit UP after panel wiping.
And here is a spot that was not sanded or polished (had wax/sealant on it from last test).
The Following 2 Users Say Thank You to Sheep For This Useful Post:
JU5T1N (24-04-2021), roscopervis (24-04-2021)
Old 24-04-2021, 07:36 PM   #15
pt1
pt1's Avatar
Great idea, thanks for doing it
Look forward to the results
Sent from my CLT-L09 using Tapatalk
pt1 is offline   Reply With Quote
The Following User Says Thank You to pt1 For This Useful Post:
Sheep (26-05-2021)
Old 25-04-2021, 04:40 AM   #16
Sheep
Sheep's Avatar
OK so I was not impressed with my performance hand wet-sanding so I decided to cut the pads down to fit my 3 inch polisher backing plate and give that a go (what do I have to lose, it's a junk panel anyway right?). Overall the performance was MUCH more consistent and it was easy to achieve a consistent haze. The issue of the fender not being flat still persisted though, which is making me rethink using this panel despite it's excellent ability to show defects. I might try a small section on the other fender and see if the performance is more consistent. Technically this fender would work, but I want this to be easily repeatable, and at this rate it's not.
Anywho, here is the photos of my attempts. I did follow up with a long UP session to see how the final results would look in a naked ready for LSP environment.
Full panel, 3000 grit, prior to polishing.
3000 grit prior to polishing
3000 grit, after polishing before panel wipe.
3000 grit, after polishing and panel wiping.
Old 05-05-2021, 05:13 AM   #17
Sheep
Sheep's Avatar
Eyes and Opinions Wanted!
Over the past 2 nights I setup 5 test sections with 5 products and after 24hours (minimum) cure I photographed them under 2 different wetting conditions to showcase the performance of each. I say Eyes and Opinions wanted as I'm trying to determine if this is a image/format/angle etc that would be considered useful.
So let me know! Is this formatting useful to you, or do you want to see these photographed in a different manner. I can try setting the panel level and getting a water bead contact angle shot from a full on side shot. Let me know. This is not the "durability" photo, I need to establish a baseline reference shot first and then I can degrade the products before photographing again to showcase the "wear".
This is the first angle I tried before switching to a different angle as I found the new (next) angle showcased the bead shape better.
DSC_2481 by brianjosephson1, on Flickr
Below are photos of the products with a strong back light, after being wet with a mist setting on the trigger nozzle (this produces the best beads the product can produce).
Wowo Crystal Sealant
DSC_2485 by brianjosephson1, on Flickr
Turtle Wax Ceramic Spray Coating
DSC_2486 by brianjosephson1, on Flickr
Mothers CMX Spray Coating
DSC_2487 by brianjosephson1, on Flickr
Turtle Wax Seal N Shine V2
DSC_2488 by brianjosephson1, on Flickr
TAC System Shinee Wax
DSC_2490 by brianjosephson1, on Flickr
Below are photos of each section after a Shower setting rinse. I moved the nozzle across the panel at a fairly high rate of speed to prevent flooding and dry-sheeting, while also slow enough to leave behind enough product to produce beads.
DSC_2491 by brianjosephson1, on Flickr
DSC_2492 by brianjosephson1, on Flickr
DSC_2493 by brianjosephson1, on Flickr
DSC_2495 by brianjosephson1, on Flickr
DSC_2496 by brianjosephson1, on Flickr
Okay, thanks for looking. Let me know what you think! I tried out the same products on wet sanded sections but wasn't impressed with the results. I will work on that and add it into the results eventually, once I have a fair comparison.
The Following 3 Users Say Thank You to Sheep For This Useful Post:
GSVHammer (08-05-2021), roscopervis (05-05-2021), sm81 (05-05-2021)
Old 05-05-2021, 10:45 AM   #18
straight6hatch
Sheep, this is absolutely excellent. I dont recall having seen a comparison like this, done in this way, before. Top marks from me. Very much looking forward to how this continues.
Perhaps making a list of sealants you want to try but dont have would be good too so we can maybe send you some
straight6hatch is offline   Reply With Quote
The Following User Says Thank You to straight6hatch For This Useful Post:
Sheep (05-05-2021)
Old 05-05-2021, 03:31 PM   #19
Sheep
Sheep's Avatar
I will down the road when I run out of my own supply, as if right now I have more than enough to keep me busy. I am going to play a bit more tonight and see if I can figure out a way to get a shot of a contact angle. After that durability testing using APC is fairly straight forward. Still working on the haze/filling abilities portion though.
Old 05-05-2021, 06:15 PM   #20
pt1
pt1's Avatar
Its all looking good pal, thanks for doing it
Sheep (26-05-2021)
